Dual discs are HOT!! They are cheaper than DVD Audio discs (which IMO, are phasing out), and they're starting to really hit the shelves! I have seen close to 20 new CDs ranging from Rock/Country (Aerosmith), Gretchen Wilson, to Jazz to R&B/Hip-Hop (Three 6 Mafia, Snoop, Dre, 2-Pac, Destiny's Child, Jamie Foxx, etc.) - Obviously, I know more of the latter (in my scope). There's a lot out there. That is the first thing I look for when buying CDs now - Do they come in Dual Disc? It is kind of like buying a DVD in Widescreen format instead of Full-Screen. Go Dual Disc...you won't be disappointed (just make sure that you check the audio format from the DVD Menu in the M, to make sure you're taking full advantage of the surround and enhanced audio).bahgee wrote:Does anyone know if those dualdisc cds work in the M? Those are the discs that have regular cd tracks on one side, and the other side is a dvd? of the same tracks in 5.1 surround sound.
You're right, not exactly 5.1, but the difference between the Dual Discs and CDs can be noticed tenfold. If you even approach midvolume (base Bose system), you feel like you're in a SoundStage or concert or something. The bass is rich and the highs are crisp. I can't wait until I add my amp/10 " MTX - just for that extra little kickjshattner wrote:Sam, I've also been seeing a lot of them, but most seem to be remastered surround, and not DD 5.1 (e.g., Beyonce) Is this changing?
Every Dual Disc that I've bought has the whole album in Digitally enhanced audio on the DVD side. Like I mentioned before, they seem to be much more abundant (and current) than DVD-A's.superjv1080 wrote:As for dualdisk, I think most material on the DVD side is videos and interviews vs. a DVD-Audio version of the CD side. At least that's what I've seen so far.
You probably have to go through the DVD Menu to start playing the concert, then move on...unless you have the hack.marker10 wrote: When I put the music dvd in the dvd audio player, does it automatically play in the audio only mode or do I have to select it from an option.
Thanks!
