ddemier7 »
https://forums.nicoclub.com/ddemier7-u214889.html
Tue May 14, 2013 7:31 am
DURAFLEX are junk.... not worth it.
I work at a collision center and customized my infiniti g35 using a fiberglass body kit and duraflex f1 fenders with vents in the side. when I was fitting and mocking the parts up, i had all the body work completed and gaps set. I took the fiberflex fenders off while I got car ready for paint. I refitted fenders and notticed the fenders had contorted/moved. the fenders curled up just sitting around in the shop. I had to put fenders in the sun and you could watch the fenders spring back to the original shape. That will piss a bodyman off quick!!!
At the end of the job the fit was abouve average but getting them to fit that good was not worth my time...nor is a fiberglass body kit. save yourself the trouble and if you must find the poly urethane (rubber) body kits. they seam to fit better.
