Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Thu Dec 03, 2009 2:18 pm
Next time search...
Should definitely buy the TT if you have the chance. Way too expensive to swap the TT into the N/A. The only reason anyone should really ever do a swap is 1) You want the weight distribution of the 2+2 or 2) you have had your N/A too long and are FAR too attached to it. (both of which apply to me
As far as maintenance goes, the engines are pretty much bulletproof. They, like all other cars, have their quirks, but nothing serious. The most common thing is injector failure, which is also one of the harder things to replace. It requires you to pull the upper intake plenum, which is about a 4 hour job. spark plugs you can do with the plenum in, but to get to #'s 5&6, you have to remove the balance tube. The main issue with working on these engines is SPACE. It's so cramped that it makes anything difficult. Trust me, though. Drive a Z32 and you will be hooked. All in all, they're a pretty expensive to maintain car, but well worth it. By far one of the most fun cars to drive that I know.
