Duplicated: Pic request - installed sandwich plate on fwd sr20de
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
ard
Car: 1989 200sx ca18det
Hi,
I duplicate my thread, because sentra/g20 forum seems to be not very informative.So, as it says:
Does anybody have a picture of installed sandwich plate on fwd sr20de?I have few clearance issues.
Thanks.
Akuma362
Car: 1994 Nissan Altima Sr20det FWD
Im actually fighting the same situation. Only diffrence is im doing mine on a fwd sr20det engine. I'll try to take some pics when i figure something out. By the way are the sr20de and sr20det engines the same as far as location of things? Ex: is the oil filter mounted in the same location?
nametakennow
Car: '06 MINI Cooper S
Yes it is.
Akuma362
The problem im having with my sandwich plate is that the stud where the oil filter goes is too long. its about 4 inches long and only the bottom 2 inch have threads so the fitting that holds the sandwich plate up against the block doesn't reach the thread and 2. even if the 4 inch long stud were threaded all the way the sandwich plate is only about 1 inch thick which leaves me with 3 extra inches of stud. It's a weird situation.
Akuma362
i've yet to find a good solution to our sandwich plate sitiuation. But i did come across this oil filter adaptor and wonder if it may be better use this and a oil filter relocation kit. I belive you would have to remove the stock oil filter mounting plate and bolt this up in its place.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
