ssnnooppyy »
https://forums.nicoclub.com/ssnnooppyy-u1584.html
Wed Apr 23, 2003 2:44 pm
Dropped some cash at the mech, and then he says "uh, I don't know". Fuel pump, okay. Plugs, wires, rotor, cap, all okay. Starter, okay. Alternator, okay. Hey, turns out my radiator is even okay.... Didn't even ask for that to be checked... So the problem persists. Vacuum??? Not sure. No codes. Car stumbles off the line, and idles odd. It hesitates all through the rpms, and bogs down under wot. EGR??? BPT??? I did the "easy diagnosis" of the egr, by pushing on the bottom of it, and nothing changed. It didn't move, and the idle stayed the same. I cleaned the living crap outta the intake and throttle body. All injectors are new. HOW CAN I CHECK THE VACUUM?!?!?!? Can I somehow use compressed air? Maybe blow it into a vacuum hose and listen for leaks? Aw geez.... I gotta get her running right... nothing is right in the world when she runs poorly. Hey, and one more oddity, the brakes are kinda weak. (new pads all around,a nd new brembo cross drileld and slotted rotors. Bled brake system, no air) I have heard that the brakes will go if the vacuum is weak.... just repeating what I've heard. I pulled the vacuum hose off the master cylinder after the car was off, and it made a sucking sound (no jokes!). help. car dying.... owner to follow......
