Dupli-Color paint compared to OEM Hypersilver on M35
jgrafe
Car: 2007 M35x
Thought I'd post a pic of the Dupli-Color painted wheel versus the stock silver wheel. The Dupli-Color wheel is a bit more matte, or dull. The wheel on the rear of the car is stock. I painted the wheel on the front of the car. I followed the directions and applied two light coats of silver, then a medium coat, then the same number of coats with the clear.
Dupli-Color
High Performance Wheel Coating
HWP101 Silver
HWP103 High Performance Wheel Clear
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
did you not paint the center cap on the wheel you did? it looks a little less matte or am I seeing things?
I like the matte look--I think you did a real nice job.
did you have to do any repairs to the rim before the painting, and if so, what did you use?
got any close up shots?
jgrafe
Car: 2007 M35x
No. I didn't paint the center cap. So far, I've painted two of my five wheels. The one in the OP I painted before mounting the tire. It has both the silver and the clear coats. The wheel on the right below I painted with the tire mounted but did not put clear coat on it. If you click to enlarge the image, you can probably see a little scuffing at the top right of the wheel on the right. The masking tape covered this area. I'll try to do a better job next time.
The paint instructions say to put on the two light coats and the medium coat about 10 minutes apart and all within an hour. I did this but didn't sand the silver before applying the clear coats. I suppose I'd get slightly different results.
I prefer the sheen of the OEM wheels, but I'll just have to get used to the more matte finish.
The wheels were scuffed and scratched a bit but no real damage. I used a regular sanding block to sand the scratches.
jgrafe
Car: 2007 M35x
In December I had Glenn and his team at Wheel Doctor powder coat my five OEM wheels. They look fantastic. I'm very pleased. The color is called Solarus. It's a tad darker and richer than the original color. They removed the Infiniti insignia and painted the center caps. Well worth $100 per wheel that I paid. I replaced the TPMS sensors at the same time. I may go back to Wheel Doctor when it's time to rotate, balance or replace tires. I know for a FACT that the last thing they'd do is scratch a wheel!
Wheel Doctor
4407 Sycamore Road
Cincinnati, OH 45236
513.886.2020
jgrafe
Car: 2007 M35x
Here's an attempt at closeup photos.
