ceniack »
https://forums.nicoclub.com/ceniack-u14675.html
Mon Mar 27, 2006 2:13 pm
just got my turbo stuff installed finally, my set-up is
revhard mani garrett t3/to4e .57trim .63a/r 480cc injectors custom rom tune for the larger injectors (by myself and david deatsch of deatschwerks) walbro 255
i know i am getting spark and fuel (way to much fuel for some reason), checked plugs and they were soaked.
i have tried reseating the injectors in the rail, as well as reseating the rail and checking for leaks at the lower o-rings, i have spark (no leaky injectors).
i have replace the plugs, wires, rotor and distributor cap.
i have had it start up a couple times, but the idle would be erratic and it would die unless i kept the rpms up.
if i unplug the injectors, the car will start up, burn the fuel in the cylinders and die, and then i can start it up with the injectors plugged back in most of the time, and if i keep the rmps up i can keep it running untill i let off the gas. and it doesn't hesitate or bog when i rev it up.
i am almost 100% sure it isn't the tune as we had kept the stock maf and tuned for the 480cc injectors and it ran fine before the turbo was installed. (doing small changes, tuning for z32 maf later)
i unplugged the maf, and it ran like poo, black smoke everywhere, didnt' make it start any easier.
i figured out how to get it started and if i keep the idle up it doesn't die, have to have the throttle completely open to get it to start however, and have even had it idleing rock steady at 700 rpms on it's own, however it doesn't last long before it dies. and i have to keep the trottle open to start it
almost acting as if i have a vaccum leak, but when i drive it it doesn't hesitate or bog unless i come to a stop and don't keep on the throttle a little, i've checked all my vacume connections and they seem to be fine.
could it be my idle air control?
or maybe my coolant temp sensor?
