1993TanJ30 wrote:Thanks for the reply!
1)Ok, so I'll drop the pan, and install a new filter as far as the transmission is concerned.
2)You have to be patient with me as far as AT are concerned - this is the first car I've owned that hasn't been a MT.
3)Now on my last car (Talon) I installed an oil cooler - it was probably roughly 6" x 6" and was mounted to the right of my front mount - where will I mount this cooler in the J30?
4)Where is the OEM heat exchaner in the J30? Is it built into the radiator or something...?
5)I picked one up from Jeg's (oil cooler) it was only like 100 bucks or something. Is this what I need or...?
6)Just trying to figure this all out, lines, etc!
7)What do you think about the 60 shot, ok?
1) And do a flush or at least fluidn exchange until the transmission fluid that comes out is all red..You will need a shops machine for that, ANd be sure to drop and clean the filter first so the flush doesnt send dirty particles t6hru the transmission.
2)No Prob..
3) They go in front of the radiator.4)Yes into radiator, this is what you want to bypass.
5)I dont know which exact part you have. there are a coupe part#'s for B&M and other manufacturers trany coolers floating around in our Q45 section, which will also apply to your car
6) transmission cooler will come with instrauctions
7) Doesnt sound unreasonable..I know a guy whos been doing 75 shot into a ( weaker than yours) Altima engine for a while with no ill effect (so far)
Fred..
