Two-Fortee »
https://forums.nicoclub.com/two-fortee-u80523.html
Mon May 26, 2008 4:26 pm
So...I just did my turbo install, and went back to stock because of a little mishap. I got some nice taka lines, and I was getting confused about which coolant end goes in which side of the turbo, got it figured out I think. Put the end coming out of the block around the turbo and onto the side furthest from the block, and the one from the intake mani going down and coming into the turbo in between the block and the turbo. I fire her up shes all good, revving it up a bit and whatnot. Then a notice the coolant in my tank is splashing around quite a bit. Soo..
Is it normal for coolant to splash around like that? Is it just the water pump doing its job?
For some reason today it stuck out at me and it never has before. Just want to make sure I got these lines right, I want my car running nice and smooth and I don't need a dumb error messing everything up. I was thinking maybe my lines were backwards, but then I convinced myself it was normal, then I had no idea, and now I am here. So. Go!
