Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Oct 22, 2010 9:50 am
I wouldn't do any kind of hammer in staples. The tack strip is pretty flimsy as ASC used a thin aluminum to make the frame of the strip. As for screws, that COULD work, but I would shy from that as they really don't have much to bite into. The tack strip material would probably fall apart once they really started to take hold in it.
In my write up, I mentioned not using the hand held staplers as they tend to not have enough umph to them, but if that's your only option, you can try it and see what it will do. Last option is seeing if anyone rents out an air stapler in your area.
