evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Jul 26, 2010 11:42 am
just to clarify:
Coolant Temperature Sensor, This si the one with 2 wires the liil like an injector clip) tells the ecu how hot the car is, this is mostly for colst start and when disconnected the ecu assumes it's cold and adds extra fuel
Coolant Temp Sender, (this si the one wiht only a single wire) this goes only to the gauge in the dash so the driver can see hwo hot the engine is, thats all it does
back to your issue of running hot, does the car stay cool when idleing? does ti stay cool at interstate speeds?
you said ti was burped properly, this means you had the heat on high and the engine warm when adding coolant right?
