dumb question
malofquist
Car: '95 240sx '05 rx8
i'm missing some fundametals, you can tell by this question.
can I put a walbro 255lph fuel pump on my stock ka24de. (i've treid searching for this).
does adding a more capable fuel pump run risk of overly enriching afr? the car is capable of only using what it needs, right?
airman86
malofquist wrote:i'm missing some fundametals, you can tell by this question. does adding a more capable fuel pump run risk of overly enriching afr? the car is capable of only using what it needs, right?
right, throwing a wally 255 in there will not make any difference to your afr. it's just capable of moving more fuel, for example in boosted situations.
