Dumb Question
ShionS14
Car: 2003 Saab 9-3, 2005 Infiniti FX35
I know that I am probably going to get slammed for this and people are going to tell me to use the search button but i just want to double check that a 1995 cylinder head will fit on a 98 motor
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
S14 motors are mechanically IDENTICAL.
'97-98 have a few extra sensors, but the same head (although the rear-most cam tower is ommitted...?)
- Brian
ShionS14
so will i have any problems using a 95 head on my 98? what sensors are not on the 95 head and will the rear cam tower being omitted cause me any problems?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
I may be incorrect, but if i recall the s13/s14 ka24de cylinder head front timing covers slightly different and not compatible. Non issue if you have the appropriate front cover for the head.
ShionS14
well the head i have is off a 95 kade motor and i have a 98 kade motor im just wondering if all the sensors water jackets etc. will work, i know the motors are identical but since the 95 is OBDI i just thought there might be some complications with an OBDII motor
