Yup. The aftermarket ones aren't made worth a f*ck. The KYB strut mount tower falls apart, literally.bradesp wrote:Curious why you suggest OEM Strut Tower Mount vs an aftermarket? Are they that different?
not much of a difference, just dont use the ones from your old suspensionbradesp wrote:Thanks!
You know, I'm a complete 4WD virgin, so no, in my two years owning my QX4 I've NEVER taken her off road! To be honest, I'd be too chicken to do it without adult supervision :-)fukinitupagain wrote:Welcome.
I noticed you aren't too far away from me (I'm in High Point), you ever go wheelin?
Shocks are just shocks. They are not part of the suspension systems other than damping out thebumps. You could drive a car with no shocks but it would bounce a lot (I remembera Car and Drive shock test ca. 1975 on (IIRC) a 'vette. One shock brand wasNONE. The 'vette was almost undriveable with NONE. You can usually change out a shockby removing two bolts.longhornsqx4 wrote:Whats the difference between shocks n struts? I thought they weere the exact some thing!
What's the tongue weight of the trailer? It should be5-10% of the weight of the trailer, and tend towards 5% I tow a 2100ishpound trailer 200 miles a weekend, tongue weight is about 120 pounds. ThePF squats a little (and there's also two sets of SCUBA gear and two tanksin the back) but only a little. It squatted a lot more when the tongue weightwas about 160.sobiloff wrote:I have a 2002 QX4 and the rear end sags pretty badly if I hook up a trailer, or load it with three friends and luggage for a weekend trip. In this condition it's quick to bottom-out over big bumps in the road and it pogos a bit as well before recovering. However, the ride when I'm alone is fine.
I know there's a TSB for the 2000-2002 QX4s that's supposed to address this by replacing the rear shock stop bumps and seats. (TSB ITB02-046.) Has anyone had this done? Is it worth it? Otherwise, I guess it's Ranchos/Bilsteins and air bags?
I'm about to replace my struts & shocks also. The strut tower mount sold here https://www.4x4parts.com/catal...d=776 seems to include the strut insulator, the strut bearing, & some type of metal washer or nut. At Nissan everything seems to be sold seperately... so which parts should I get from them to replace when I'm changing the struts?fukinitupagain wrote:These would work well:https://www.4x4parts.com/catal...=2049
And I ran these until I destoryed one of them on the trails a while back:https://www.4x4parts.com/catal...=1906
Since you are not concerned about offroad perfmance you won't need any kind of heavy duty shocks or struts. And you don't have to buy from the websites I sent you to; get them wherever you find them cheapest, I'm just tryin' to give you a starting point.
Also you will want to replace the strut tower mount (get the Nissan OEM) & you'll probably want to replace the rear lower arm busshings (they are cheap, will outlast you R50 & make the ride quality sooo much better). You can get the strut tower mount from the dealer & you can get the poly bushings from here:https://www.4x4parts.com/catal...=4998
