Redline240https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=054b479a07762afcbd6335d02669b915Dumb Question, be gentle....Sat Jan 18, 2003 10:53 am
Postby
Redline240 »
https://forums.nicoclub.com/redline240-u3445.htmlSat Jan 18, 2003 10:53 am
How the hell do i get the bloody stock shift knob off? i got the plastic framing and boot off but the little **** just won't budge, what am i missing? go easy on the flaming, just help a guy out.....
Postby
big jon's 240 »
https://forums.nicoclub.com/big-jon-s-240-u1784.htmlSat Jan 18, 2003 10:53 am
Dude, you gotta just keep twisting, pulling, and cussing. It took me forever to get mine off. Just keep going at it, its stuck on there like a mofugger. Get yourself a good pair of vice grips and pull.
Postby
Anand »
https://forums.nicoclub.com/anand-u165.htmlSat Jan 18, 2003 10:53 am
i took one of those plumbing tools that will grip itself on to a pipe and then just pushed the hell out of it.. it ripped the rubber of my shifter but it sure as hell got that thing out in 10 minutes... I got a new shifter anyways... so I didn't care if i ruined that one!
Postby
b240 »
https://forums.nicoclub.com/b240-u2547.htmlSat Jan 18, 2003 10:53 am
big jon's 240 wrote:Dude, you gotta just keep twisting, pulling, and cussing. It took me forever to get mine off. Just keep going at it, its stuck on there like a mofugger. Get yourself a good pair of vice grips and pull.
BigJohn you know one of my best mechcanical secrets!!! Curse at that mother fu.cker as much as you can. Then if it still doesnt come out cuss more and get more vulgar if you can. That should do the trick man.
Postby
Redline240 »
Well it's good to know that everyone else had the problem, but i wanted to check before i broke something.....so just twist and pull the **** outta it hey? alright....
Postby
MaineExport »
https://forums.nicoclub.com/maineexport-u157.htmlSat Jan 18, 2003 10:53 am
Try driving it around for a while to heat it up. The bond seems to be weaker when it's warm. Then, I used an oil filter remover (the kind that has an adjustable rubber strap) to twist it off. You really just need to get mechanical advantage/leverage on the S.O.B. and twist like it's your job!
Postby
wingzero »
https://forums.nicoclub.com/wingzero-u2571.htmlSat Jan 18, 2003 10:53 am
smack that b1tch around and show her who wears the pants around here......then just be like, "hey, you go make me some pie, or knit me a sweater biatch! RESPECT my AUTHORITAH!"
