Interesting.. All the similar systems I have seen stayed off when you turn it off..champagneG35 wrote:When I did those donuts on the dry pavement with my vdc off. It mostly stayed off....what I mean by mostly is that since I was paying attention to where the car was going I wasn't looking at the dash. It never tried to stop wheel spin or anything but it sure got freaked out. When I finished I noticed the slip light was stuck on but vdc said off. Tried to turn it back on to no avail. Had to pull over turn the car off then start it again and everything was back to normal.
BTW, your Z looks sweet! I want to get me one of those baby some day..Do you have L24 in there? Or did you swap it with L28?
I have the L28 in it. Dual SU Sidedraft carbs, upgrading to FI and CAI at somepoint when I have time. Have all the parts minus one little rubber hose/coupling to connect the throttle body to the CAI.Minmey15 wrote:
Darius's Z is sick...but so is this one which honestly I'd rather havegrantman240z wrote:My first 240z was a '72...the L24 threw a rod and decided to melt together. I felt that was the perfect time to build the 3.1L Stroker out of an L28 and slapped the triple Webber setup on her. Man, that was a fast little car and sounded sick too.
The 350 swap is great for a drag car...make that 2000lb car fly. Darius is still my hero with that LS1 in his 240z.
mine does the same thing when i do donuts... as far as ive been able to tell if the vdc is off but the slip light is on like when we do donuts vdc isnt actually kicking in.. i think its more of a precaution to let you know that you just sliped the hell out of it...champagneG35 wrote:When I did those donuts on the dry pavement with my vdc off. It mostly stayed off....what I mean by mostly is that since I was paying attention to where the car was going I wasn't looking at the dash. It never tried to stop wheel spin or anything but it sure got freaked out. When I finished I noticed the slip light was stuck on but vdc said off. Tried to turn it back on to no avail. Had to pull over turn the car off then start it again and everything was back to normal.
