nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon Jul 18, 2005 5:53 pm
I'll be replacing my stock injectors with 370s when I go turbo in a couple weeks.
So, question.
The stock SR20DE fuel system is a 3-bar setup, right?
This may be completely off, is the physical size of injectors based on the bar too? Like are all 3 bar injectors, regardless of manufacturer (aftermarket or OEM) the same physical size?
I know Nissan 370s are the same size as my stock Nissan injectors, so they will swap right into my rail, I was just wondering about aftermarket ones.
What Nissan/Infiniti cars had 370s from the factory?
This is a 2001 Sentra SE w/pp.
edit: Nevermind, got an answer from Michael.
However, I've been told that RR SR20DE injectors are side feed, he said top feed (and low impedance - sp?). He seemed to be in a hurry when he posted, so maybe he forgot which SR I have.
Which setup is on the 00-01 SE SR?
Modified by nametakennow at 8:18 AM 7/19/2005
