JonPowell wrote:Take a crappy weight distibution car, like say a porsche....rear engine rear wheel drive WAY biased to the rear and a perfectly balanced car with the same power, total weight and tires...you drive the perfectly balanced car and throw oh say MICHAEL SCHUMACHER in the other unbalanced car.....I guarante consistently better lap times from the unbalanced car.
A good driver will adjust to whatever the car can handle. If you are the professional you think you are a little different weight bias wont hurt you for more than 10 mins before you can adjust your style to still get the most out of the car.
My Porsche has a near perfect 50/50 weight distribution (probably 50.50/49.50 or something). Stock is ~51/49 and mine has some slight weight reduction in the front. I agree though, the driver is ~99% of it IMO.
Dareo, as far as a 100% perfect 50/50 distribution, that's going to be hard to acheive for a reasonable price and not doing anything more drastic. Though, I wouldn't get so focused on this. I will say that it does make a good difference, however it isn't everything and vehicles without a 50/50 split can still handle perfectly fine. You don't have to have a 50/50 distribution to be able to have a neutral car. Use suspension to adjust for this. You can use an adjustable sway bar in the front and/or rear to adjust for neutral/over/understeer.
As far as an RB swap affecting the balance of the car, it is going to have an affect. Although I look at it like this, modify the suspension to compensate and maybe do some weight reduction to offset some of the weight gain and you should be fine. Also, the RB is physically a taller engine than the KA I believe, so a portion of that weight will also be sitting higher in the car. Personally, I would do ab RB swap at least for the sound. I like i6's more than i4's and, IMO, an Sr/Ca/Ka will never sound as good as an Rb. Isn't that reason enough?
