False. There isn't enough duct tape in the world to keep a Tempo runningMinisterofDOOM wrote:Holy crap, there's enough tape there to keep a Tempo running but none of it appears to be doing any good. Someone clearly failed Structural Duct Tape Applications 101.
Clearly not a drifter. Drilled holes with zipties are stronger than duct tape...canadian booster wrote:awww yea! haters gonna hate! hahaha this guy rolled into my work for repairs, i think
Thats fantastic. Bring it to Carlisle.Hijacker wrote:Fun fact: 3M makes a red duct tape that the Navy uses in its nuclear department that is absurdly strong, and according to Deidra will suspend a 200 lbs man to many objects.
I'll see what I can do.frapjap wrote:Thats fantastic. Bring it to Carlisle.
Actually, you are confusing foil tape with duct tape. The commercial grade of gray duct tape is not the same as the stuff you buy in any hardware store, and the foil tape is usually used outdoors or when close to a condenser coil or heat exchanger of some type.Hijacker wrote:Also, true Duct Tape won't work for most applications. You know, the silver kind? And true silver duct tape is the only kind you should use on HVAC, the gray duct tape that everyone uses to hold the wold together won't last long on an HVAC duct line.
Bubba1 wrote:Clearly not a drifter. Drilled holes with zipties are stronger than duct tape...
Must get a roll of this!Hijacker wrote:Fun fact: 3M makes a red duct tape that the Navy uses in its nuclear department that is absurdly strong, and according to Deidra will suspend a 200 lbs man to many objects.
