Well.....
This weekend has been a real eye opener for me. Firstly I took apart the entire engine down to the bare block. Needless to say, this is what I found was causing me my issue.
This piston some how got a piston ring into a location it should not have. I admit this was probably my fault, but I didn't have any issues with it when I put the pistons in the first time, rather didn't realize I did.
This is the reason why I got the big 0 psi for cylinder 1.
I took the bare block, crank, heads, and rods to the motor shop in our town and had them take a look. They informed me that the cylinders are now going to be getting bored out .040 due to some cylinder damage. I am getting all new pistons and rings, keeping rods, new rod bearings, checking valves for any damage, clean and tank everything, and having them then put the bottom half back together.
Needless to say, the single turbo setup is now on the back burner with as much money as I am having to put towards getting the motor up and running. So instead I bought:
New exhaust manifolds
Going to make custom intercooler piping
New T28 turbos to upgrade from the T25's that I currently have.
New HKS sequential BOV's
New head gaskets
New timing belt (I replace everything less than 20,000 miles ago, but I am not liking the timing belt I currently have, better safe than sorry)
Everything else will stay the same as far as the motor is concerned.
New Rear sub frame bushings, mine are starting to ooze their liquids
A friend of mine is hooking me up with a manual conversion that he is keeping an eye on. Which I would rather have than an automatic any day of the week.
I have done a wire tuck on the front and moved the relay box from the driver front fender to under the driver head light. And its just as easily accessible. Redid the exhaust a while back and when I took out the old piping I found that it was restricting the air flow down to 1.75 inches in some places from s*** welding. I am glad to report that it is a solid 2.5 all the way back, and the mufflers have been tucked under for a better look with less sticking out.
A little bit of work ahead of me on this, but she is worth it.
Can't wait till she looks like this again! The vinyl is still in really good shape considering I put it on back in 2009 or 2010.
