Dual stock fuel pump?
nismo1003
Car: Ka24de
I got a 90 S13 KA-E, just wondering if I can use dual stock fuel pump to push a set of 440cc for 8 psi. just a thought, if not I probably go with 255lph. thanx in advance
jab11185
Car: 1992 Nissan 240sx
why bother going through all that trouble when a walbro 255 is 99 bucks?
EDIT: you are running some sort of fuel management right?
nismo1003
Car: Ka24de
yes, I know there're 255lph are available, but I would like to know if it does the same thing with 2 stock pump( i have a extra one at home)
I'll be editing the stock fuel map then burn a Eprom to a ECU or use use ram to input data(mircocontroller)
jab11185
is it possible.....yes
will it be worth the time you spend fabbing up brackets and wiring and plumbing...not really
and as far as functionality, really not sure about how that would perform
save yourself a crap load of time and work a get a walbro or similar aftermarket pump....
