crew93tt »
https://forums.nicoclub.com/crew93tt-u45297.html
Sun Nov 26, 2006 2:29 pm
I have a 93TT with 120K miles. I have what appears to be white or very light colored gray smoke coming out of both exhaust. There is a slight oil smell associated with it. After a few minutes of warming up the smoke dissipates. Some morning it takes longer to clear than others. It seems to smoke more if the out side temp is cooler. It also smokes under the following conditions. After sitting several minutes, it smokes after a restart. If I due a rapid acceleration or down shift putting the engine under a load, it puffs smoke. Sometimes when I come to a stop, it smokes. Other than that, It's a strong running Z.
I've had the car appx 8 months. It had the following mods: Larger inner cooler, high flow intake, Stillen straight pipes (no cats), ECU chip, Apex I SAFC2 Air Flow Controller. and a PRofec B-Spec2 boost controllercontroller
