tg »
https://forums.nicoclub.com/tg-u52200.html
Fri Dec 04, 2009 8:39 am
My tuning guy said, and he is VERY knowledgeable on the subject and has tuned several high HP Z's and skylines, that the absolute best way to go is to get two MAF's (instead of 1 maf and an ecu tune that doubles the signal) and use a modified GTR (89-93) ecu with it as it has dual MAF inputs on it. You basically wire the second maf back to the ECU harness where there are extra pins for it. This eliminates all issues of irregular idle + stalling at highway speeds with the clutch in etc. since the skyline had two maf's (one for each 3 cylinders and turbo) this method works particularly well because you can seperate the two intakes (unlike the 'doolz') and have your ecu manage fuel independantly for both banks of the engine, keeping everything parallel.
Thought i was a good piece of information to share for those looking to push over 500hp and looking for a reliable setup that is even better than the 'dual maf translator' they sell.
The reason for this is that the maf signal is not linearly proportionate to the amount of air coming into it. To explain it further, say you have the stock single MAF setup. With the engine OFF and the key ON, the signal is 1.0V, which means the ECU thinks 0 air is coming in.
Now, say the car is idling and there is 80cfm going into the MAF, which registers only 1.2V, letting the ECU know that its taking in enough air to supply enough fuel for say 800rpm of activity at idle. At redline, the car is taking in 650 cfm of air, the maf will register 5.0V (estimated). This lets the car adjust for the right amount of fuel to supply 350 cylinders per second.
Now, say you have one MAF on one side of the dual intake, and you have an ECU mod to accommodate for that (the map is changed internally, so it will say at 1.1V, supply enough fuel to accommodate for 800rpm and at about 2.5v supply enough for redline [just for example, not definitive]). In theory this technique works well because you are changing the ECU to accommodate, but this technique does two things that are undesirable. Firstly, it doesn't take into account the fact that one side might be taking in more air than the other... un-even filter wear, air disturbance in the front facia at speed (stalling at highway speeds, anyone? ). Secondly, you lose your 'resolution'. Think of resolution as just what it implies, the amount of points a MAF can register between 1.1V and 2.5V is less than between 1.2 and 5.0V. Furthermore, if your MAF isn't in perfect condition, the inaccuracies are DOUBLED with this technique. Say our MAF is burned out slightly, what would have been a slight lean condition before just became twice as bad. There is also the issue that a MAF at 40cfm will likely not register 1.1V instead it will be closer to 1.05 or so, but the ecu is tuned for this so it doesn't matter.
SO, the other alternative thus far has been an adapter that allows you to put two MAF's and connect them both to your ECU along the normal MAF adapter and you don't need to tune your ecu (unless you change your injectors, which everybody who NEEDS to run dual intakes has to). SO this method is superior because it takes the average of the two MAF's and send it to the ECU which fixes the problem of having uneven airflow etc, but this causes another problem. At Idle, your MAF's are only registering 1.05V each, and when sent to the ECU at 1.05V it thinks your car is doing 400rpm instead of 800 or whatever, because it is non-linear, but in general it works better than the aforementioned method. It costs about 280$, and an extra MAF, making it more expensive than the previous method.
Now, the Skyline GTR ECU method solves both these issues because it has two inputs for MAF sensors and takes into account the idle issue and the disambiguation between both sensors. Disadvantage is that you need an R32 ECU (about 140$) and you need to run an extra set of wires to the ecu. The result though is a completely reliable idle and perfect metering up to 1000hp. It is a bit less expensive than the adapter method but requires more work+more knowledge on the matter of wiring and tuning.
I'll let you guys know how it goes next week along with details and some dyno vids!
Modified by tg at 2:38 PM 12/4/2009
Modified by tg at 2:41 PM 12/4/2009
