dual intake manifold for PRE 07s!
chad1200
Car: 2004 G35 AT Sedan
stumbled across this somehow. $1600. aftermarket dual intake for pre 07 Gs.
http://www.speedforceracing.co...i.php
this got me thinking, though. anyone know if the 07 intake manifold will fit on a pre 07?
Modified by chad1200 at 5:25 AM 10/30/2007
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
I'd just do something like this
"all the fastest trucks are running dual filters"
The more air you can get into the motor providing you have the ability to add fuel proportuneatly the faster you can go!
MA04g35x
Car: 2004 G35x Twilight Blue
Sweet! Is that electrical tape I see?
joe603
Car: 2014 Durango R/T
Here's the problem...the VQ35HR and the VQ37 use dual MAFs, dual throttle bodies, and a dual inlet plenum. You would need a different ECU to tune everything....$$
It would only be worth the money if you wanted to go high boost...
chad1200
poop
gwoods
MA04g35x wrote:Sweet! Is that electrical tape I see?
YEP, I was out of duct tape. The tubing came with a EGR port precut. I had long ago bypassed the EGR so I didn't need the port and it was too big for a nitrous nozzle.
Dual filters will still give you more air and possibly more HP is you can add and burn more fuel.
Jeff
gday
hot air intake FTL!
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
+1 hot air FTL
gwoods
gday wrote:hot air intake FTL!
At the track I used dryer ducting to run the filters out the fog light holes in the bumper. On the street it worked fine. I cut out the plastic fender liners on both sides. I have Pace Setter longtube headers jet hot coated inside and out. You could touch the headers with your bare hands a min after the motor was off.
But whatever you think Mr 19 posts
Q45tech
All that counts is the WOT air temp in plenum/plenums and the pressure drop from 14.7psi atmospheric. At WOT the plenum pressure is still >13.9 psi at redline.
Why not measure both and see if you can beat the teams of factory engineers with their millions of dollars budget.
joe603
Q45tech wrote:All that counts is the WOT air temp in plenum/plenums and the pressure drop from 14.7psi atmospheric. At WOT the plenum pressure is still >13.9 psi at redline.
Don't give me that crap! The manufacturer weighs the cost benefit of engine design. Their million dollar budget allows them to design systems that will do the job, provide airflow into the engine in this case, but as cheaply as possible. An aftermarket part does not have this constraint (to a point).
Just remember the case of the Ford Pinto. Ford's engineers knew that a $5.80 part would make the car safer when in a rear-end collision. However, they had 2 million Pinto's sold...a $5 part would be quite an expensive fix! They are in the business to make money first.
gwoods
SEMA is a big waste of time for you hu
I backed up my modifications with testing at the track where it counts.
The truck ran a 15.7 @80 mph when I bought it in July of 2004 and was running a 14.0 @ 98 mph when I sold it in July of 2007. That was with the transmission slipping I'm sure had I kept the truck I would have saw high 13's this winter. Looks like I beat the engineers pretty badly.
Air temp is important but once it makes it to the intake manifold it warms up pretty quickly.
If the million dollar engineering budget was for performance aftermarket parts would not exist.
G_whizz
Car: 2010 G37 Coupe Sport
MA04g35x
Very cool
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
X2 haha, he said Mr 19 posts, time to go shoot yourself gday :P.....j/k, welcome to NICO I noticed you joined a couple of weeks ago
TKLEI14
Car: G37
first one is very nice, but not worth 1600$
gday
again hot air intake FTMFL.. haha.
