almost all parallel setups i've seen had check valves. did you take industrial hydraulicsDarius wrote:Why would you need check valves in a parallel setup? The pumps are going to be running simultaneously.
I would run separate wiring to each pump and make it heavier gauge than stock too.
Not sure what most people do, but I can't imagine trying to squeeze two pumps down in there. I had a hard enough time getting the damn supra tt pump in there.
haha dude. I do more hydraulics than anybody on this whole f**king web board, so let's get that out on the table. Your idea of being able to run one pump if the other goes down is fine if you are looking for redundancy of single operation.sepulchralx wrote:
if one pump goes out, and there is no check before they T into a single discharge line, the pressure may go through the outlet and back out the inlet of the downed pump, losing pressure.... It all depends on design of pump. If it has some fail-close design it could be fine.. This is my main concern.
If you have one pump and it goes out... your car just shuts off, alright.
If you have two pumps and one goes out, and you dip in pressure, your engine will lean out... which could be a disaster
haha, do it, then we can chit chat about it.. Btw, what size injectors are you running?Darius wrote:You can wire in pressure switches to the EMS?! Man, the flexibility of that system is making me want to ditch my PFC.
There about 1000X more things you can do with the aem vs a pfc . I ditched the pfc/datalogit 4 years ago. But what I'm talking about is just using the high/low boost switch function of the aem. Just using a switch, relays and pressure switches you can do that. Basically you'd need a ground at the high boost switch and both pressure switches to raise the boost limit. Or you can just set the pressure switches in series and they will be the boost swicth Or if you want you can even set the second pump to turn on at a certain rpm or psi with the output functions.Darius wrote:You can wire in pressure switches to the EMS?! Man, the flexibility of that system is making me want to ditch my PFC.
There are lots of good books on the subject. Even your local Barnes & Nobels will typically stock them. My suggestion is to start with a good book, or a tutorial from one of the EMS providers. Honestly the internet has probably just as much good info as bad info.sepulchralx wrote:Do
Do you tune your car yourself? I really want to be self-sufficient and not have to rely on anyone to tune... Know of anything good besides the aemforums that could teach me the basics of fuel map and ignition timing?
Yes, tuning a mild (less than 500whp) setup is easier than most make it seem. You already have a base map which is the hard part. Read the aem forums for boost comp and read the aem EFI basics manual and also Freshalloy has a very good thread about tuning in the "best of" section.sepulchralx wrote:Do
