So I started putting together a intake manifold for the KA the other day. Basically aluminum sheet with stock runners. I bought a brand new IACV I will mount on the rear of the plenum and I intend to install an AN fitting on the rear to accommodate my vac manifold. The two main reasons I am building this is due to the stock design, it makes the right side of the motor difficult to get to. Making heater hoses, IACV hoses difficult to work on. I beveled the edges of the plate that I welded to the runners so that it acts as a velocity stack and calculated the volume of the plenum just over 2x the displacement of the motor (ideal from what I understand)
I am also creating a stock side feed fuel rail with dual feeds. I bought a couple fittings from Mcmaster and turned them down to fit inside of the rail. So the rail will have two AN6 fittings on either side and a single return to a remote mounted FPR. I did this to avoid replacing my 850cc side feeds with a top feed/rail setup that I can't afford for my build atm. And to get around the issue with the stock rail leaning out on the last injector at higher horsepower.
Let me know what you all think, any suggestions etc.
Still a ways off from being complete, but ill keep it updated as I go along.
