BoostFab »
https://forums.nicoclub.com/boostfab-u11693.html
Tue May 25, 2004 8:18 am
This may be some help to you.
The schematic will activate the fan anytime the coolant temperature is above the threshold of the thermostat. The fan will also turn off when the ignition is off.
Switched 12V can come from the ignition on power.
Power for high current devices like fans should be taken directly from the battery. This avoids loading down other circuits which may not be able to handle high currents. The fuse is absolutely necessary, and should be located as close (physically and electrically) to your 12V source as possible. 30A is a typical value, but if you can get by with a smaller fuse by all means use one. You will see that we use the thermostat to activate the relay, which then switches the fan. Grounding can be any common source, but it is best to make your ground as short as possible. If you use the chassis as ground, make sure to scrape away any paint that could interfere with your connection.
The thermostat will typically have a probe that is to be positioned on the radiator somewhere.
