xckid »
https://forums.nicoclub.com/xckid-u23378.html
Wed Jan 06, 2010 1:26 am
its been over a year, since my car has ran right. Im at a loss of what to do i have the timing dead on and it still does not start. My cams are postioned the right way i followed the jim wolf article my dist is dead on my firing order is correct. Ive got a rebuilt head on it new head gasket new intake manifold gasket, new valve cover gasket, new upper cam shaft chain tension-er, ITs set on compression stroke. The pulley is set to the second to last notch on the left side. I have fuel and spark i checked for spark early todayFuel well you can smell it from all the times not starting. My car just cranks but wont turn on. Im at a blank im going to try and do a compression test tomorrow. If i have to ill tear off my head again but god knows i dont want to do that currently going to school, this car is wreaking havoc on my sleep. I have a new battery also and as of now my starter seems to be staying on longer when i stop trying to start it .....Ive tried moving the dist over a tooth and nothing it just sounds like it wants to start but doesn't so ill reset it back to stock. To make things worse im sure things have only gotten worse because before my car would at least turn on and run like poo and now it doesnt turn on ......
Need to get it running now that my family is down to one car since i totalled my blazer, this car has to be running. Please shoot any thoughts
sorry fo the wall of txt need help
side note im no longer doing the dual exhaust cam swap this is all on stock 91ka cams
