I had a discount auto brand (dont rem anymore) 16" pinned to my radiator for 2 yrs. I just wired it up into my ac fan harness. It was ok and only ran when the ac kicked on or the temp hit 200, like the standard fan. In the florida summer however, if I turned my ac on andwas either idleing or in traffic it would go up rather fast.
One summer in particular I was on the Dayton bridge about halfway up with my ac on and it strats blowing out hot air. I looked down to see it just at the top line of the normal range before headding into hot. Turned the ac off and my car was surging from the heat. Trafic wasm oving about .5 mph and there was no emergency lane. I turned on full heat and defrost on and cranked that thing. I was melting and the temp didnt drop, I barely made it off the bridge. Another minute or two and I would have started gushing fluid I sure.
Anyway while I did last 2 summers with it, had I have shrouded it with aluminum and lifted it 2" off of the radiator I dont feel any of this would have happened. I was only effectivly cooling 60% or so of the radiator.
I just sold that to my friend with a rather modded TT-Z and helped him make a shroud and wire it in (coulda wired it himself if he didnt slice his damn hand open with a razor hehe). I replaced it with a set from a 96 altima. No they dont fit, in an s14. I had to take about 1/2" from each side overall, another 1/2" - 3/4" x 4" so it would slide between the frame rails, and some of the extra reinforcement plastic off of the pass side shroud so it would clear the ac liquid tank. Then I had to modify the tabs to work with the rad bolt holes and the bottoms dont line up either, so I am making some alum brackets. I wired the pass side right into the harness and the low speed of the drivers side into a new relay to constantly stay on. This aids with airflow over the headders reducing under hood temp. Basically did the same thing as on that sight (didnt even read that hehe) but with a second relay, added above the one showed. Then I wired the high speed into the a/c harness as well.
Total parts involved a new used relay (low speed operation relay), 2 male 4 prong nissan connectors and a female 4 prong (used from the yard as well) to make a Y harness to give it a oem look while wiring it all together, some solder and some splitloom / tape
Works good but I think since low and high are wired together inside the motor, and high is both wired together and grounds as well in the "Y", im sending current through to the other fans low speed as both come on when I turn the ignition on. No big deal as it works and if I get picky Ill just add another relay.
Btw they move some serious air. Just letting it idle with the ac on, my frame just before the radiator (the part the rad bolts to and the latch) was cool to the touch from the air getting sucked under it. Cost me virtually nothing as I sold the 16" for $50 to cover the cost of the alti fans
