dual electric fans
rhtuners
Car: 1992 240sx se coupe Ka24DE-T
o.k. so i have read some posts on swaping out your belt driven fan to an electric fan read the pros and cons and now i am going to do the swap but the only thing is what year altima do i get the fans from or does it not even matter????? do they all have double fans in them??? any help would be appreciated if not i can just go to the zone and pick up a single fan....
180fan
Car: 89 fastback
then you haven't read the important ones nor the relevant ones.
u13 altimas. you'll also need something to trigger them. yes dual.
single 14" will suffice
search and lurk moar will be the last bit of advice on the matter.
sidewaysdan
Car: 1990 240sx
i put a single fan that i pulled off a 98 grand prix all you have to do is wire it in with a relay and tap into the ignition so its all ways on wit the car on it keeps you cooler all the time make sure you us a big gauge wire so you don't slow fan speed down...also you can make your own brakets wit that old fan mounts.....
rhtuners
thanks for your input sideways
