dual cam ka24de cluster qusetion?
Unstock240
Car: 89 240sx se
Can i use my 115mph speedo in the 110mph cluster?
Modified by Unstock240 at 4:42 PM 5/20/2009
Bongpain
Car: 92 240sx
you know that when you have real question about your car and seriously needs help; you will never get it on this board. speaking from experience. but i will try and throw out some possible idea. one if you're question refers to a stick on speedo indicator and stick it on your old cluster, i am sure you CAN'T. why because the motor that count your speed is still reading the 110mph. that will give you false reading. if you use the whole cluster as long as the wires are in the same location between those two cluster you will be fine. hope that helps and hope if you have any good idea or advise for the next trouble person you pass it on the good words. I myself needs help but not anyone useless unrelated to the subject. tnx
Unstock240
Car: 89 240sx se
I looked closely and the only difference seems to be the number spacing, so i think they will work. I'm just used to the 115 and its 5mph more I guess. I am going to try it tomorrow and see if my gps reads accurately with it in.
