Dual bolt pattern wheels...what to do with extra holes?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
blueversa wrote:Speedy lite 7'sZeno tires 205/40/17dropped with Tanabe nf210 springsNo rubbing
What can one do to cover up the other holes from the 2nd bolt pattern on aftermarket wheels?
biggie
Don't know of anything, no one I've seen has ever covered them.
Possibly could find plastic caps, but they would be coming off.
Kolk1
Car: 2007 Nissan Versa
Your best bet would be to try and find a set of NON dual pattern rims. But good luck, since the only reason we have so many rim options is because of all the 4x100 rims that come dual pattern.
brainguyus
Car: '12 Nissan Murano SL
'08 Nissan Versa SL
'67 Lincoln Continental
I'm surprised the wheel manufacturer doesn't offer a cover.
If you're determined to do something with them you can get some ideas here....
http://www.levelingmounts.com/caps/
Stuff Kleenex in them.
...or duct tape.
Seriously, there's nothing you really can (or should) do.
Those holes tell the world that you bought wheels that will fit a Honda AND a Nissan, so roll with pride, my friend.
williamk10
I duno, i've always thought seeing the rusted hub was ugly...
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
You could always put some colored Vinyl behind it or even carbon fiber Vinyl?
KimberKenobi
Car: the Camel
some wheels (like say my Konigs I'm getting in March) come with all the bolt holes covered... problem solved.
Return to “Versa Technical Discussions”
