Bjudd454https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=3abccaf730d769cc9d6f3ad27e0f3308Dual Automatic Window controls on Drivers side.Tue Feb 09, 2010 11:06 am
Postby
Bjudd454 »
https://forums.nicoclub.com/bjudd454-u153020.htmlTue Feb 09, 2010 11:06 am
I have a 2010 HB S with the power pkg so only the drivers side window is automatic.
Is there anyway make the passenger side window automatic and replace the button on the drivers and passengers side door? How hard is this process?
I ask because its a pain, I live in AZ and my windows are always down and unless im going through a drive thru i rarly roll down just the drivers side.
Postby
Francesco »
https://forums.nicoclub.com/francesco-u135330.htmlThu Feb 18, 2010 4:17 pm
Bjudd454 wrote:is this an impossible task? no one has replied!
I do not really know, but, I suspect it cannot be done since it is programmed into the body computer so adding an extra switch for the passenger side may not work.
Postby
Codelicious »
https://forums.nicoclub.com/codelicious-u134434.htmlFri Feb 19, 2010 12:41 pm
So all of the other windows are manual and you have to roll them down with the knob? Or are you talking about how the driver side all you do is push it down once and it goes all the way down?
Postby
Promise Land »
https://forums.nicoclub.com/promise-land-u128757.htmlSat Feb 20, 2010 2:20 pm
As Francesco said, the switch is is tied to the Body Control Module which controls the auto function. The switch is the easy part to add if you are comfortable with the wiring portion. You'll have to re-program the BCM, which will take someone with a Consult-III to do.
