DTC code P0505 02 Q45
squadone619
Car: 2002 Q45
I cleaned my throttle body awhile back and got a service engine light, showing code of P0505. I need to smog the car and don't know where to start in getting the code cleared. I was going to change the throttle body with a 04 but that didn't go thru yet but need to smog asap. I read the FSM on the code and I don't have any intake leaks. My idle is higher than the 650 rpm normal operating. Its at around 970 rpm at idle. Checked my timing and its good at 17 degrees. I know I messed up something when I cleaned my throttle body but I'm not sure what the heck it is. Thanks
also, I was changing my spark plugs and had my intake tube off and noticed that my throttle plate is partly opened. Is it suppose to be shut while car is off?
Modified by squadone619 at 11:00 AM 7/9/2009
