DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Aug 21, 2005 9:11 pm
The code is saying that the bank is reading too little fuel. Could be from a clogged or faulty injector, low fuel pressure (that would probably trigger both banks though), sluggish O2 giving a bad reading. If the code is valid and/or if the ECU is trying to compensate for the error, such as run too rich, then the vehicle is not running as well as it should be. Its peformance and/or mileage could be suffering. No smog check will ever fail you for emitting too few hydrocarbons, but that would be a problem. How were the NOx numbers relative to the averages?
Maybe when Wes has some free time he can list for us which error codes don't really matter.
