DTC access 2003 maxima se
mlahc56mlahc
Car: 2003 Nissan Maxima SE
SES light on and need to determine how one accesses the DTC so I can determine the problem and how best to address.
audtatious
Pull codes? Go to a local Autozone (or whatever) and they can pull codes for you.
mlahc56mlahc
Called local AZ and they wanted to know if I knew where the DTC code plug was located. Any clues?
audtatious
I believe it is under the dash to the left of the steering column or around the fuse box area.
Q45tech
One needs the *.pdf version of FSM to look up codes [given by scanner] to then follow proceedures to identify problem.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
audtatious wrote:I believe it is under the dash to the left of the steering column or around the fuse box area.
That or this sticky:zerothread?id=126537
audtatious
Q45tech wrote:One needs the *.pdf version of FSM to look up codes [given by scanner] to then follow proceedures to identify problem.
Of course, which is why we have the FSM's available.
