dtc 45 is an injector leak, right?
mss5413
Car: Nissan 240sx
Hey guys,I have a 93 240sx and the check engine light does not light with the car running but I am still able to flash a code 45. I replaced the injectors already,and it will still flash 45 after resetting. Maybe the injectors did not seat correctly? Any tips on how to install the fragile injector o-rings? I know to use engine oil before installing them.
Also I can hear a hissing out of my muffler at high end when I punch the accelerator. Is this normal? I do have about 160,000 and it is the original exhaust.
neverlift
are you sure its not a 55 which is code for clean ecu/sensors
mss5413
Car: Nissan 240sx
right, 55 means no faults. I'm positive that it a code 45. Post some ideas please guys, thanks.
blabla
got the same code wich is only suppose to come out on California Models...
And mine is defenitly not a CA car... so I dont know - I just spend 50$ at dealership for all the orings and insulation involved with the injectors just to make sure the problem is fixed when I get to it....
