I'm pretty sure I can do this and have researched the bejesus out of it, but I wanted to confirm once more in case any of you guys are/were DSM guys.
I have a TD05 turbo that I want to replace the turbine wheel shaft on.
I'm fairly certain that I can use a TD05H turbine wheel shaft on it since the housings are all the same. I just want to be sure that the diameter of the wheel isn't changing and that it will not have fitment issues.
Is that correct? If not, why?
