DSM injectors
snowy_s13
Car: S13 Silvia, CA18DET
I'm trying to find injectors for my CA, the only thing i have left now before slapping on the new turbo etc. Just want to make sure, are DSM injectors straight plug and play or do i need a resistor, etc? Also would 550 cc be too big, i am getting my computer chipped etc with custom maps right after i get everything on, he should be able to dail them back without a safc right? Thanks
89'ClubK's
Car: 89' Nissan 240SX
Yes, DSM injectors are a direct fit. Wiring is the same, resistor doesnt' need to be changed, and use the CA O-Rings. Mine are 450cc though, don't know if they made a 550cc. 550cc injectors are not too big. Car will run a little rich, but that's ok.
biosehnsucht
Not all DSM injectors are direct fit, need to be sure they are low impedence or you'll have to bypass your dropping resistor..
The bigger you go on injectors the harder it is to maintain low speed drivability/efficiency, especially on a stock or modified stock ECU.
ca18det89sx
WUT YEAR DSM INJECTORS WOULD FIT 89-94 OR THE 2ND GEN 95-UP
