DSM injectors a direct drop in in a Rb20?
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Hello i was looking at some dsm injectors i heard they were a direct drop in in a rb20 i was looking at some 550cc ones, i searched but hopefully wont get grilled by the search button monkeys.
Thanks!
DriftingisLame
Car: '91 240sx coupe, rb20det
90% sure DSM injectors drop right in... Also CA18 ones I've been told work as well.
I wont tell you to search because i want to know for sure too
RB20DETodd
DriftingisLame wrote:90% sure DSM injectors drop right in... Also CA18 ones I've been told work as well.
I know same here 90% haha that extra 10 sucks,
http://cgi.ebay.com/ebaymotors...wItem 300 shipped not bad.
Valley
Car: 00 celica gt-s 89 240sx hatch
if CA ones work then DSM ones should work... i've been cruising the other motors and recall peeps there asking for DSM ones... may want to go over to the CA and ask specifically though?
masticatingcow
Car: 94 Mazda FD3S
What you're looking for are top-feed, high-impedance injectors. I'll bump that percentage up to 95% sure. I think you need to save your O-rings, but beyond that, I think it's a pretty straightforward install.
Carl H
dsm injectors require the rail be machined a bit to work.best bet is to get supra mk3 injectors and a resistor pack, call it a day.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
DSM injectors are 440cc stock Blue tops. Anyways I test fitted my old 660cc Denso injectors that I used in my 1G when I had it into a Rb fuel rail and went in like a charm.
Carl H
Yellow4g63 wrote:DSM injectors are 440cc stock Blue tops. Anyways I test fitted my old 660cc Denso injectors that I used in my 1G when I had it into a Rb fuel rail and went in like a charm.
orly?i had a ca friend who tried dsm injectors in his car and they wouldnt fit without some sanding......perhaps the denso's have a smaller inlet port?
Cornloaf
Car: 1990 240sx
i believe rx7 series 5 injectors are direct fit. they are 550 cc and you dont need a resistor pack
unstable240
Car: OG RB20DET
Yes they fit right in, but they are a little harder to find from what I have found...
RB20DETodd
Cornloaf wrote:i believe rx7 series 5 injectors are direct fit. they are 550 cc and you dont need a resistor pack
What years is the series 5?
foCk
89+ FC3S
