DSM/Evo Injectors in a SR20DET???
JerichoNike
Car: 240sx sr20det
1g 450cc top feed(high Impedence)
EVO VII Top feeds(high Impedence)
Has anyone used these before?
I have sets of both these laying around my shop and was wondering if they would work properly with the sr20det?
A friend also has a set of 880cc top feeds for an EVO VII Im thinking of picking up.
otterman
They wont work without a new fuel rail and clips.
It's a bad idea, that is all.
JerichoNike
Car: 240sx sr20det
why a bad idea?? are they the right impedence? top feed injectors are generally cheaper and they dont even make 1000cc side feeds that im aware of so ill have to go top feed.
do i need a resistor box?? i have all the wiring pigtails and all but i wanna make sure theyll work
Btw i have a Blitz tuned ecu(tuned for 480/550??)But im running stock 370cc injectors and theyre running like crap cuz the ecu is programmed for bigger injectors.
otterman
JerichoNike wrote:why a bad idea?? are they the right impedence? top feed injectors are generally cheaper and they dont even make 1000cc side feeds that im aware of so ill have to go top feed.
SR/KA injectors are high impedance so the EVOS will work if you really want to.
If you're really thinking you'll need 1000cc injectors then you'll have to go top feed. I guess it's all depending on your plans for your set up, most people don't need 1000cc though.
