DSM 550cc injectors
ilovecoupes
just wanted to know if DSM 550s will fit in the stock fuel rail. i know 440cc will, with diffrent O-rings. Not sure about 550s
http://slowboyracing.com/estor...age=1
ca18det240hatch
if stock 4g63 injectors will work, then im sure upgraded 4g63 injectors will work. Youre putting them in teh same fuel rail....so if one works, then the other has to.
ca18det240hatch
Other injectors that will work for your application
87 rx7 turbo II injectors, should be tan top, notch in the center,low impedence 550cc. Red tops will not work unless you bypass your dropping resister.
GTI-r injectors, 440cc, yellow top, they are direct drop in, low impedence
skyline GTR injectors, which are same as the above, yellow top, 440cc.
hope that helped. good luck.
mbmbmb23
Evo 9 injectors.......560cc low imp.
Gotta love people who dont know what they're selling http://cgi.ebay.com/ebaymotors...18558
Cha ching.
