is he sure it is 550's & not 450's? It seems like it will fit since dsm 450 works.
From ka-t.org
ka-t.org stickie wrote:Typical Injectors Used on SOHC
DSM (Eclipse/Talon/Laser) 450cc Injectors *Low Impedence*RX-7 T2 550cc Injectors *High Impedence* Denso 195500-2020RX7 FC NA Top feed 460cc Low *86-87*RX7 FC NA Top feed 460cc High *88*RX7 FC NA Top feed 460cc High *89-91*RX7 FC turbo Top feed 550cc Low *86-87*RX7 FC turbo Top feed 550cc High *88*RX7 FC turbo Top feed 550cc High *89-91*RX7 FC NA Top feed 680cc Low *84-85*CA18DET 370cc Injectors *Low Impedence*
And DSM's use low impedance, so you need resistors - either getto rigged, jgstools.com custom resistors, ebay, or dsm/honda resistor box wired in line. There is a DIY on this forum by fiznat - think it may be an article or sticky lying around somewhere.
