DS power window inop and switch making noise
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
yazmo
Car: 05 Nissan 350Z roadster
Power window for DS inop, switch making noise up/down. Replaced switch twice and fixed issue for awhile then back to the noise and inop window. Pass side works. Motor replaced 2 times by me, og motor seems to have been replaced by prior owner, still not working. video below of issue.
https://www.youtube.com/shorts/MZxtbJvQm_U
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Is that noise coming from the switch or the door? If it's coming from the door, you probably have a shot regulator and not a shot motor. Excess current from a jammy regulator can kill the switches along with the motors, so your new switch may have gone south too.
yazmo
Coming from the switch. The switch/motor gets power but it gives my test light a dim light.
VStar650CL
Technical Expert
Check the ground and power pins into the switch, especially the ground. Blackened female pins are easy to miss, and overheated ground pins are a fairly common issue.
Return to “350z / 370z Technical”
