deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Feb 14, 2006 5:38 pm
A dry sump has multiple pressure feed lines and scavenge lines, a turbocharger is just another feed and scavenge to add to the system.
A dry sump pan is intended to hold as little oil as possible. As you can see that pan has 2-4 scavenge points. The oil drops into that small cavity and is sucked out by the scavenge lines asap. It is designed to hold maybe 1/4 qt of oil during operation.
You normally have multiple scavenges all over the block (and head), at least 2 pumps, an external reseviour and external oil filters in the system.
EDIT:Here is some dry sump examples.
Z series
Art schmitt team ka24de
60's era LZ twincam rally engine.
