Just wondering if any of you have come across this problem before I take in to Nissan dealership and get told is something silly.
I don't think this is normal as I've gone through puddles before and deeper than the recent one. But yes, it might be the speed that I've went through the puddle this time around.amc49 wrote: ↑Wed Aug 15, 2018 2:35 pmUh, if you have water coming in door bottoms or under the steering column, that is NOT a puddle people, it's gross driver incompetence. Choosing to go into water WAAAYYY too deep instead of going around it; when water is that deep the ripples on top will generally tell you but you must THINK about it. Cars under those conditions are NOT and never will be waterproof (the insulation guy was a laugh riot!), the guarding there is against light to moderate splash rather than solid bulk water, which will come into any vehicle on the planet if deep enough to get over the bottom of the car. Anything past 4 inches is too much but they apparently can't get that across in school now.
If hearing a new noise then likely a rubber seal or similar has been displaced by the water impact and more evidence of way too deep. You can see the new generation do it all day long on the weather news, 90% of the water crossings now are incompetent and they should not be doing it. Common sense went out the window when the last president showed up.
sey wrote: ↑Tue Aug 14, 2018 2:46 pmI'd like to bump this issue as this is the same issue I have... Well, I've driven through puddles before and didn't have any issue, this past month when we were getting a lot of rain in Houston, TX I've driven through a dip on the road (specifically a commercial area through the parking lot) with a puddle of water. Then *Whoosh* water came gushing through and same as the OP, now, I'm hearing the engine noise a little louder than it used to. Seems like there's a hole now after going through the puddle. I don't know if it matters but I've got a 2014 Nissan Altima S, Sport Value + Audio package w/ remote start.
I was searching through the web for a solution and water gushing in looked like this (mind you this is a 2016 Nissan Maxima)... https://youtu.be/UUdsGikWN6o
