qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Tue May 05, 2009 5:10 pm
Today I had Frank Hill { Hill's Garage in Baltimore} replace my weeping turbine sensor and replace the rear main and tailshaft seals along with installing a new flexplate {my old one had a few chipped teeth and occasionally grinded when starting the engine}
Frank was positive he could remove the transmission without removing the exhaust, even though the FSM states it must be removed to drop transmission- I watched in shock as he unbolted and positioned the hydraulic transmission jack into position- and sure enough, he was right as I watched the transmission slowly descend from its home and clear the exhaust with room to spare!!! I am shocked the FSM says you must remove exhaust, as clearly you dont, and on a old Q with original exhaust, you really dont want to wrestle with those rusty old bolts and clamps if you dont have to!!!!
Frank examined driveshaft and determined it to be in good shape at 227,300 miles. All in all, another wonderful experience dealing with this shop- professional, knowledgable, personable, and fair pricing.
