Dropping the S14...which camber Kit would you guys recommend.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Like the title says, I'll be dropping the S14 pretty soon and need to know what camber kit most of you guys would recommend to reduce negative camber...Any help would be appreciated. Thanks.
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
ingalls offset camber bolts they are reasonably priced for like 50.00 front and back and give u upto 2.75 degrees of adjustment. How low are you gonna go? if u slam it then go with rucas, by slam i mean 3 inches or lower.
adrianfromthecastle
Car: 1992 Nissan 240sx
more info on what your using to drop it with.
If youre going with coilovers, hopefully it'll come with front camber plates. Then get SPL rucas.
WI_S14_Goldie
She's gonna be dropped with coilovers...so SPL RUcas ey?
Slappy
Car: 1993 240 sx coupe
If you get coilovers that come with Upper Pillow Ball Mounts , then thats all you need to adjust camber in the front.
The Rear Upper Control Arms are for adjusting camber in the rear.
You do not need camber bolts like the ones H&R sell if you have Upper Pillow Ball Mounts on your new Coilovers.
If you wouldve searched life , you wouldve known this.
whiterps13
Car: white LE hatch
Get SPL RUCA's..
