Make sure that you are indeed without a dropping resistor and if so, I think I have an extra one that can serve your car better as I don't use them on my set-ups. And 'YES' a loom is a harness as the dropping resistor is also called an injector resistor as well.dsilvia89 wrote:so since i used the harness that came with the engine, this means the loom was changed?
a loom is a harness? thats all? (just for clarification)
i am not able to go look at my car tonight, but i will check tmr for sure.
i am almost certain that i do not have one of these dropping resistors because i dont recognize that item at all, and i mean i did the swap and worked on it for hours, it is recognizable. sooo... what to do? (once i know for sure i do/dont have a dropping resistor
also, the car is a 5 speed transmission. i am not able to say if it was ever an automatic. i hope not :P is there any distinctable things i can do, or look for to find out weather it
was an automatic at some point in time.
The injector resistor is a plug and play application. It's not complicated, but you will need one. As for the injector drivers, they are in the ecu and I really won't worry about ecu damage just yet (seriously doubt it), but I hope your wiring is correct or there could be more issues later. Again, you'll need to acquire an injector resistor, plug attach it to your harness and see what happens.dsilvia89 wrote:i am for sure without a dropping resistor.
there is a clip that looks like it could be plugged into the image above. looks like a perfect fit. and where that is coming off the harness about the same place my MAF
sensor clip is.
i need some information on how to hook this dropping resistor up, as i didnt even know it existed till a couple days ago :P
also, boost_boy could you give me information on the injector drivers? you mentioned the resitor could be my problem and result in the injector drivers failing.
i would just like to know where these are, what they look like and what to look for if these have resulted in wrecking also. thank you guys sooo much
On the contrary, injectors will fire, and they will draw more amps, because the resistance of the injector circuit is about half without the dropping resistors (I=U/R). But still, that should only be a problem if your ran it like that for a long time, and on a high duty cycle (high RPM with high load), so that there was enough heat buildup to damage something. If yours didn't even start, as everyone said you should be good after plugging them in.D_Stirls wrote:You won't have any ECU (injector driver) damage because with no dropping resistor plugged in there will be no current drawn as your injectors wouldn't be firing at all.
Once you plug in the dropping resistor providing there is no other wiring issue you should be up and running.
Oops, that's true. I got it mixed up in my head with a honda I worked on last week, which had a short circuit plug in place of the dropping resistor plug....D_Stirls wrote:With the resistor not plugged in then there will be no circuit created. It's a DET loom so the injector circuit goes through the resistor plug. Without the resistor being plugged in there is no circuit.
