Dropping Resistor
Supra7
I have a couple questions. I have been reading up and determined that I need a dropping resistor. The questions I have is first of all, does anyone have one lieing around that I could buy off of you as that would be the easiest thing. The second question is failing that, is there any other dropping resistor on another car in the US market that you guys know of that will work. I did search and I also read your crossover parts, but I failed to dig anything up. Thanks again guys!:help
NeedCAforS13
Car: CA swapped S13 coupe
It usually comes with your wiring harness? And there is one on ebay now, but its about to end i think? A pulsar might use one...but I'm not 100% on that.
boost_boy might have one laying around...and I'm sure themadscientist can get one for you (but since he lives in Japan it might take awhile)
welcome to the CA section of NICO:) That 1jz powered rx7 sounds sweet! got any pictures?
Sean
Supra7
Thanks for the info and welcome! My FC is pretty fun, i am the current high bidder on that resistor, but freakin hell man, thats spendy! My REX is out of comission right now getting something new....probably a 2J...havent decided yet :) here is a pic of the engine bay right after it was finished, its kinda dirty tho
Nismo1182
Car: Z06
A 1G DSM one looks similar.
Theres a few mitsu parts on the CA. Take a look at the front of the cam angle sensor ;)
moomoomoo
I'm using one from a CA18DE pulsar, so that should work!
Supra7
Thanks guys!!
